Hi Guys,
I want to use a  FGS211 relay on the wall socket that the washing machine is plugged into. When the machine cycle has stopped I want to set up a scene to monitor the  FGS211 and if the power usage drops below a certain level ( I will measure working and standby power draw to find this out) then I want HC2 to send an SMS or push to notify me.
Will the  FGS211 be able to be interrogated this way?
Has anyone got a scene LUA code already to save me some heart ache please?
5 answers to this question
Have fun
does the FGS211 have energy consumption measurement? If not you could use a wall plug.
here is my scene:
%% properties
909 power
%% globals
-- create a 'AGD_Wash' variable with 3 values = OFF, ON, READY
-- check if Scene started more then one time
fibaro:debug("-- SCENE START --")
fibaro:debug("-- Scene Instance: "..fibaro:countScenes())
if fibaro:countScenes() > 1 then
fibaro:debug("--SCENE ABORT - too many instances --")
fibaro:abort()
local WPS = tonumber(fibaro:getValue(909, "power")) -- (change to your ID)
local WS = fibaro:getGlobalValue("AGD_Wash")
local TS = tonumber (fibaro:getModificationTime(909, "power")) -- (change to your ID)
local TDS = tonumber (os.time()) - TS
fibaro:debug ("AGD_Wash ="..WS)
fibaro:debug("power = "..WPS);
fibaro:debug ("time = "..TDS)
if WPS == 0  and WS == "OFF"
then
  fibaro:debug("abort")
  fibaro:abort()
if WPS > 200 and WS == "OFF" or WPS > 200 and WS == "READY"
then
  fibaro:setGlobal("AGD_Wash", "ON")
  fibaro:debug("Applience is ON");
  fibaro:call(693, "turnOff")
if WPS < 10 and WPS > 0 and WS == "ON"
  then
  fibaro:sleep (120*1000)
  fibaro:debug ("sleep")
if tonumber(fibaro:getValue(909, "power")) < 10 and WS == "ON" -- check if WPS is stable < 10W
then
    fibaro:debug("Applience Ready");
    fibaro:setGlobal("AGD_Wash", "READY")
    fibaro:call(913, "sendDefinedPushNotification", "3"); -- push to mobile1
fibaro:call(835, "sendDefinedPushNotification", "3"); -- push to mobile2
    fibaro:call(693, "startProgram", "751");    -- RGB-Ligth flashing green
fibaro:call(469, "pressButton", "4");      -- voice command
fibaro:call(469, "pressButton", "5");      -- voice command
--------------------------------- waiting for switch off
if  WPS == 0 and WS == "READY"
then
fibaro:debug("-- turn OFF --")
fibaro:setGlobal("AGD_Wash", "OFF");
fibaro:call(693, "turnOff")                         -- flashing RGB off
fibaro:call(810, "pressButton", "1")           -- tone signal
Many questions already asked here. If you did a search, you already could have used it
HC3
DeviceID is plug
if you want to announce washer actions:
scene (left)
(right)
@uaetechnition, When I lived there I found one on Sheijk Zayed rd. (Number I forgot)
Succes,
//Sjakie
