kmeta 2
Hello
I have scene which is activated when Fibaro Switch 2x1.5kw change the value.
Few times per day scene is activated becuse switch change the value (0 and 1) with out any reason (push buttons).
Here is the log:
I use this scene to activate Day and Night mode in the home. And you can see that at 05.20 am it's not good idea curtains to start moving
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />.Same is happening with my Garage door (use Fibaro switch 2x1.5 to control it) - some times scene witch open/close it is activated becouse HC2 detect that switch change the value.
[DEBUG] 06:27:39: 650
Do you why this is happening and how to avoid it ?
