Hi guys,
I am thinking of getting Davis Vantage Pro2 model 6152EU  weather station to work with my fibaro. i was googling the setup but could not find how it is done - does DAVIS require LAN connection to my local network? Or does it offer WiFi? How do you set it up?
I love my Vantage Pro2!
You will also need either the WeatherLink or the WeatherEnvoy to be able to get data to the Internet, otherwise you will only be able to monitor the data on the display unit.
If that is all you need then you are done.
There are a couple of different options, so do your research first.
I have the WeatherEnvoy IP version.
    ah ok i will have a look thanks
