AEON LABS Multi Sensor - humidity
Hi
My Multi Sensor works ok for Lux, Temp, and motion, but I do not think it reports humidity ok. It has not changed since I installed it 2 days ago. Is there a setting in parameters I need to tweak?
5 answers to this question
The defaults work for me. But maybe your setup is not like mine.
I would indeed check several parameters. And also see If the HC2 updates when you wake up the device with a single click of the button.
Regarding the parameters, I find it difficult to explain. Because it is indeed a somewhat peculiar setup with groups and bit masks. Can I refer you to the technical manual? Pllease come back if you have questions.
My settings are:
I had, on occasion, a MultiSensor that no longer updated temperature or illuminance. I went for the short pain to solve it: exclude / include.
    Thanks for the manual! I will try some tweaks
    Did you get this to work? I'm having the same problem. Motion, Lux, Temp but no humidity.
    For me it's the motion sensor that isn't working. Any tips, anyone?
    I've manually added all parameters (they refused to show by itself), and made sure they match the manual and what others suggested here;
    but so far to no avail. Everything seems to update and work fine except the main thing I'm after, motion sensor.
    I've turned the Sensitivity knob all the way to max but it's just as dead
    /emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />
    It should be parameter 5 (1d, 2)
