I have three FibaroEye sensors
the trigger for motion works perfect but the Lux stucks eg Lux 102
when three times pressing the inner button it works for about 1 ore 2 hours and stucks again
is this a nowing issue ore......
thanks
Hi
Did you change in the settings the lux value interval to something useful below 200 lux?
Will say that the eye will report changes in brightness in intervals less than 200? I have set it to 10 and it works....
Kandetvara
    i have try to change the value from 200 to 10 (parameter 9)
    but it gets back to 200
    Change the setting, wake up device, refresh the page, that should normally do the trick.
