can the fibaro door/window sensor be included in the global alarm panel ?
So that alarm appear on event without using custom lua scripts?
Greetings
Our FGK sensors work natively with Alarm Panel. What exactly is the issue?
    there is no problem. Just wanted to check that before buying
