Phone and Port Forwarden
I have a question about Port Forwarding. I had already searched here on the forum about it , but it will not work correctt. What have I done. See VD script and script to activate it .
Have an app downloaded PF and have it put on a port eg 37503 .
VD script :
tcpSocket = Net.FTcpSocket("192.168.0.65", 37503)
bytes, errorCode = tcpSocket:write("test")
if errorCode == 0
then
fibaro:setGlobal("PapaPhone", "1");
else
fibaro:setGlobal("PapaPhone", "0");
Script to activate:
%% autostart
%% properties
%% global
PapaPhone
local TimeRun = (10*1000)  --sec
local VDPingPhone = 660 -- VD id
function tempFunc()
fibaro:call(VDPingPhone, "pressButton", "1");
fibaro:call(VDPingPhone, "pressButton", "2");
 --print("Locating")
setTimeout(tempFunc, TimeRun)
if ( startSource["type"] == "autostart" )
  then tempFunc()
if fibaro:getGlobal("PapaPhone") == "1"
  then fibaro:debug("Thuis")
  else fibaro:debug("Weg")
Also tryied forwarding on my router
on my phone a have a app to run open ports
when i start the PF on my phone i see on the app open port scanner that 37503 is open
when i start the activate script i see in the variables that it works
but after a few sec its gone and the scanner dont see anny open ports
the longest time is about 30 min and than gone and gomes only back if i restart the PF on my phone
who can help mee
regards Kage
