Get IP from MAC address
hi,
i cannot set sonos to static ip. can you pls suppor me fine ip from mac address..thanks a lot
6 answers to this question
open your sonos app on your smartphone, go to settings, then Info on my Sonos system and there you have the IP address.
or log in to your router en search via the DHCP menu option for the Sonos mac address and it will show you your IP address.
cheers
emiel
    thank you,but ip dhcp will change. scenes can't update ip sonos
    How about assigning an IP on your router basing on MAC address?
    but sonos always has a connection, so if dhcp lifetime is default like 24 hours it should never change ip address.
    ok...thank a lot
    No, but the DHCP-server may get rebooted etc... Most consumer stuff does not save the lease table in persistent memory.
