Parameter 13 RGBW Unable to set at 0, wondering why it is not possible to set this to zero, minimum is 2% and that keeps the switch still on, so difficult to make a scene (on/off) with it.
see pictures for more details it is a V2.5 module and latest release on the HC2 (not the latest Beta). So when i select the "0" ticker box and safe it, it will get back to default 2%.
There should not be checkbox with value 0, thanks for report. Please refer to manual in such cases, there you can find that there is no option to set 0 to this value, since to dim the light to level lower than 1% you simply turn it off
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
  • 1 month later...
Guest samuelboerhoop
same to me, light with be off but in display it shows that the dimmer is still on. What to do ?
