Hello Forum,
I have a strange behavior of a FIBEFGS-222 Switch. I a turn the light on with the Switch I see no Change on the Websurface. So I can not see if it is turned on or off.
the FIBEFGS-222 nearby Shows this Change without any Problem.
Waht can I do?
MIB
Hi MIB,
too little info
1) Did it ever work before?
2) Did you change anything (SW update)?
3) Have you tried to disconnect and reconnect the device (include / exclude)
4) Can you switch it via the software - if so - does it show the right status?
kandetvara
    Hi kandetvara,
    sorry for too little info.
    I have about 50 FIBEFGS-222 switches. HC2 Version 4.053 Beta.
    1 - It works on most of the modules. If those particular one ever worked or not I can not remember.
    2 - Yes I had to mess around with the system and made updates.
    3 - Yes it did not help.
    4 - yes I can switch via software and it alters the image and shows the correct status.
    MIB
    • 1 month later...
    Ok it seems to be an never ending story.
    I include a FIBEFGS-222 switch in my test scenario.
    It works now as on/off switch.
    ON / OFF = changed position of switch key (toggle switch)
    If I press the switch to on I can see on the computer browser that it was turnend on.
    If I change to Momentary Switch I do not see change on the computer browser anymore?
    WHY?
    MIB
