Google Translate API text-to-speech: http requests forbidden
Dear, team Fibaro and people.
I have problem today with SONOS and HC2 TTS.
Google TTS not work more, It;'s banned IP or have captcha.
And request from HC2 Lua virtual device not work.
Please help me, can you give me code for example play file or http link .mp3
Thank you.
14 answers to this question
This has happened to me too - really frustrating as i have several scenes which are reliant on this
Same story, I guess google changed something or there is a max amount of requests per day.
Hope its a temporary thing or I need to research again into a new tts solution
    I think google now set captcha and SONOS can't use link any more, we need or write proxy script or
    Just listen .mp3 files with my records voice play from my server not google.
    But help me with script to play files please.
    Thank you.
    Ok... So i figured a few things out... i can send my sonos pre-recorded mp3's but now i need a way to select which one. im using the speaking Sonos VD to trigger the TTS but now i also want it to change the name of the file being played...
    This is the krikoff code that i edited. notice the x-file bit..
    line 1313        "<InstanceID>0</InstanceID><CurrentURI>x-file-cifs://David-PC/TTS/tester.mp3</CurrentURI><CurrentURIMetaData>"..Sonos:createMetaData("TSS by Google...").."</CurrentURIMetaData>",
    I left the google bit there coz im not a programmer and not sure what that does...
    Now i have a global variable that i can change(just added a line to each button) to say tester1.mp3 but how do i add the variable into krikoffs code?
    Like i said im no coder so kinda just added what i thought might work and left the rest as is coz i have no idea what most of it does
    anyone? please?
    Ok
    found a solution on another forum
    you have to add , client=t after the UTP bit. see code below. it works 100%
    x-rincon-mp3radio://translate.google.com/translate_tts?ie=UTF-8, client=t".."&a".."mp;tl=".. (lng or "fr") .. "&a" .. "mp;q=" .. (urlEncode(message or "") or "message") .. "</CurrentURI><CurrentURIMetaData>"..Sonos:createMetaData("TSS by Google...").."</CurrentURIMetaData>"
    Genius -I'll try that as soon as I get back to the UK - remote access has stopped since the latest update too!
    Ok
    domotique-fibaro.fr ?
    I have tried to copy the above and replace it on my VD but it still doesnt work. Is there any chance you could send me the full code?
    Many Thanks!!!
    "<InstanceID>0</InstanceID>,<CurrentURI>x-rincon-mp3radio://translate.google.com/translate_tts?client=t".. "&a" .. "mp;tl=".. lng .. "&a" .. "mp;q=" .. urlencode(message) .. "</CurrentURI>,<CurrentURIMetaData></CurrentURIMetaData>",
    Can you try this:
    I can use the link on my PC and it works fine - How do you translate the url to the lua code from this...??
