mvdkallen 0
Hi all,
Once I leave my house and set the house in "away" mode (.. which means it will close some roller shutters, close some curtains and arm window- and some door sensors through a scene), I also would like HC2 to communicate to me in case I left a window open by accident.
I had a look online for LUA code examples, and in specific to examples where the "elsif" parameter is used, but I got confused and am stuck now...
Anyone who can help me out here, please?
I only need to know the part of the code where I actually request HC2 to check the device status and report back in case it does not meet the requirement (.. as example, if Window A is open, send me the notification... If Window B is open, send me another notification... and so on.
Just take the below IDs as example when writing the codes:
Window sensors
ID35 for Window sensor A
ID36 for Window sensor B
ID37 for Window sensor C
Notifications as set in the system
ID40 for Window sensor A notification
ID41 for Window sensor B notification
ID42 for Window sensor C notification
Smartphone
ID 50 for smartphone Mark
.. probably the LUA script is quite simple, but right now I just don't see how I need to program this.
Thanks a lot for anyone's advice.
Best regards,
Mark
4 answers to this question
