How to control a Fibaro relay module within a VD?
Guest samuelboerhoop
My ceiling fan works on IR, because of that I used a itach IP2IR module with an IP address and TCP - Port
I added a couple of buttons and programmed them, all working fine.
I bought a Fibaro relay module, to switch on / off the complete ceiling fan and instead of using the interface from the module, I would like to use the top button of the Ceiling Fan remote called "Ceiling Fan on / off"  (see Photo-1)
What Lua code do I use to switch on / off the fibaro relay module (see Photo-2) within the interface from the Virtual Devcie ?
4 answers to this question
if
fibaro:getValue(device_ID, "value") == false
then
fibaro:call(device_ID, "turnOn")
else
fibaro:call(device_ID, "turnOff")
    I tried this but not working... as in... copy / paste your code:
    %% properties
    79 value
    %% globals
    if
    fibaro:getValue(79, "value") == false
    then
    fibaro:call(79, "turnOn")
    else
    fibaro:call(79, "turnOff")
    I tried something else with a scene: lua blocks and then you can see the conversion lua code:
    %% properties
    79 value
    %% globals
    -- local startSource = fibaro:getSourceTrigger();
    if (
     ( tonumber(fibaro:getValue(79, "value")) > 0  or  tonumber(fibaro:getValue(79, "value")) == 0 )
    or
    then
    local deviceValue1 = tonumber(fibaro:getValue(79, "value"));
    if (deviceValue1 > 0) then
    fibaro:call(79, "turnOff");
    else
    fibaro:call(79, "turnOn");
    ------ the scene is working, fan on fan off, etc...
    I copied this code for the button "CEILING FAN ON / OFF", at first it wasn't working as i pressed "debug"
    The debug told me that line 7 was (nil) so I put the line as not active.
    After that it was working. Thanks a lot
    Guest merylion
    First of all this line is wrong:
    returned value type will be STRING not BOOLEAN so it should look like
    fibaro:getValue(79, "value") == '0'
    I changed the code again to the following simplified code:
    %% properties
    79 value
    %% globals
    if
    then
    else
    All workis perfectly
