In the corridor I have two lamps, each with its own switch and each with a Fibaro FGS221 (Double Relay Switch). They are on two different fuses so I can't have a wire between them.
I want both lamps to go on and off at the same time no matter from which switch.
Who can help me how to program this in the HC2?
Can you tell me more informations? Like how many inputs you are using in your Fibaro switches, how many lamps (outputs) in each swtich do you want to control.
    I have 1 output (lamp) en 1 input (switch) on each Fibaro relay switch.
    So you can just associate both switches to each other in 1st association group. It should be all what you have to do.
    Thnx, works like a charm
