light scene problem using motion sensor
I'm looking for some help to optimising my lightling scene(s)
I tried to find some related posts, however I can't find something that is related to my problem.
In my house I use several motion sensors (fibaro) to control my lightsmodules (qubino & fibaro) Locations: Restroom, Hallway Frontdoor, Hallway Upstairs, living room, diningroom and Kitchen
Now the problem is related to al the scenes, so I will explain everything using one case.
In my livingroom I have:
1 x Fibaro motion sensor
1 x Qubino Dimmers
This scene works fine, however the problem is that after 1800 s my lights turn off and it takes some time to reactivate it. I see that the motion sensor is detecting motion, but it does not reactivate my lights on quikly. I tried to play with the parameters from the sensor, but I don't get the result I want.
I my most ideal situation, the motion sensor is breached, turns on the ligth for 1800 sec. and after 1500 s the motion sensor is checking again for motion en when motion is detected he send antother signal that the ligths should be turned on again for the next 1800 sec. If not, the ligt can be turned off after the 1800 sec.
Is it possible to create this using building blocks and divice parameters, or do I write in LUA?
you could try @jompa68 exelent lua script for this
    Thank you....I hoped I could program it using the graphic blocks, however I can't find anything that works.
    I tried the script and it works fine!. I also changed the LUX parameter(s) in the module. It is probably better to add this function into the script, but I first need to learn some more skills in LUA-programming.
