thermostat "SECURE SRT321 relay module FIBARO FGS221
hi I have a thermostat "SECURE SRT321" I tried to attach it directly to a relay module FIBARO FGS_221, but it does not work you tell me how do I make the association so check if I made the right step by step thanks
Did you solve this problem, because I wasn't to know the answer too.
Solved this problem in the end. Not sure how. Just kept making associations an d saving - eventually it worked. Trouble is, it seems to me, there is no proper users guide to the software and it's use. The set up is straight forward, but to a beginner, the use of the software is far from clear.
