Post request with HCL
(I am French, Google translation)
I have a POST request to send to an application by a virtual device, but it does not work.
The POST request must be sent to: "
It must have an argument : "event" with the value : "test".
How to write it in the virtual device ?
Thank you
4 answers to this question
Give it a try:
Remember to fill in IP and port addresses on the top of the Virtual Device configuration page. Authorization is base64 encrypted in format login:password
This works for our interface actions, I am not sure about the device you are using, but it should do, it's a standard way.
    Thanks for the reply.
    But I had already tried this command but without success.
    And there is no need for authentication.
    And control works perfectly in curl :
    curl -X POST "
     --data event=test
    So the problem is not with the software in question.
    It comes to "LM Remote Keymap" that sends infrared signals or execute commands on the remote computer.
    Sorry, but I am afraid I would not be help any further with access to this device to give it a few tries. Maybe another user with this device will be able to help you.
