>Hello!
Are there no Parameters predfined in the HCL for the Relay Switch?
It may be that Relay Switch is in version that was released after premier of your HCL firmware - in such case it was not possible to include it. You can adjust needed parameters manually, referring to the manual for their sizes and values.
    So, that means the switch is to new for the HCL?
    Sorry, I might have expressed myself wrong: you can use it and it will work just fine, only thing that is not implemented is parameters template: you need to adjust parameters manually. All needed data for that can be found in manual.
    Ok, I understand. But is the template missing because I have version 3.xx?
    And another Problem, today i installed a double Relay Switch. 30 Minutes all are ok, but then, nothing works on the Switch. With the Push button on the Relay Switch i cannot turn on tje Lights and it smells a little bit like Plastik.
    Yes, it is because software is older than device. If device does not react on wall switches even after power cycle it may be physically damaged, please verify the connection and module itself.
    The connection is correct. But why does it die after 30 min?
    @chrisblueeyes sorry but I do not know, I have no access to device nor controller. If you can smell plastic I would make sure module is not physically damaged. Also please contact support if that behaviour persists: such things are rather hard to solve over forum
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
