Hello.
my first days with fibaro und first problem.
The instruction manual says "Fibaro Switch is set by default to operate with momentary switches"
I only own momentary switches!!!
But my new FGS-212 is set by default to operate with toggle switches.
How can I change parameter No.14 to
0 - momentary switch?
My home central is not a fibaro, I can't do this easy in the software.
Regards
Marco
As far as I concern every controller give possibility to change parameters, you should contact your box manufacturer to ask how to do this.
