Harmony Plugin, use devices?
Hi All,
I saw that you can add the new plugin (harmony) and it's AWESOME!
The only thing is that you can only see the activities, is there a way that we can also control the devices separately?
Thanks for your fast aswers!
Regards
Hi can you tell me what hardware you use? Is IT the hormony home hub?
    I've got a Harmony Smart Control!
    Hi
    I got the same issue...I can see and assert my "Activities" but cannot use them in eg "Block scenes". I have the "Harmony Smart Control" witch is the hub and a simple remote. Can it be that there are different hubs?
    I am not sure if I am doing anything wrong but is it not possible to automate the Harmony plugin through block scenes? This seems to be typical Fibaro. Same with Sonos plugin as well. Please understand that I already have a remote or a dedicated app for controlling my media devices. The only reason I would like Fibaro integration is to be able to automate. Sometimes Fibaro feels like going back 15 years in time and having 7 remotes in front of you. Please Fibaro when you develop plugins let us use easy and graphical setup processes. Not all your customers can program in LUA.
    Harmony is not available with block scenes so far, sorry. Only Lua scenes can utilize our plugins right away.
    Do you have an example how we can leverage with LUA?
    Yes, a LUA example would be very good,please provide. I´m not a programmer myself, but with good examples and the "HC2 Block scenes to LUA-convertor" I can do some programming.
    All actions and values that can be used with given device are listed here
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
    Hello!
    Thanks a lot, this is great functionality and opens a lot of possibilities.
    Thanks. I have a problem with the hub connection with the HC2. After some days the conneciton is gone (hub is not connected the HC2 says), after I remove the device and re-add it, it works again... any idea? The hub is working with apps etc etc but sometimes not with the HC2
    How do I know the activity ID? I cant find it anywhere. So I can Use it with Virtual Device
    Agustin
    Enter the activity and see the url:
    Number at the end is ID of activity.
    Hi Fibaro
    I have now installed and tested the Harmony Hub with LUA, and I agree with the author of this thread Frakke that we should be able to assert commands on devices. Being able to assert activities only is very limiting. Every activity start with an "on command" and finishes with an "off-command". I would like to send other commands.
    Also, I would like to combine the "IR-device commands" with my Fibaro devices. E.g. power TV-consumption can verify that the TV has been turned on, otherwise I´d like to resend the on command.
    So Fibaro, would you please consider implementing access to commands of the Harmony devices?
    We would love to, but this is unfortunately all we can do with Harmony API, implementation of devices is not supported by Logitech itself.
    Logitech announced the Harmony Hub Extender. It makes it possible to control more home devices than ever with expanded ZigBee® and Z-Wave Plus™ compatibility.
    Also Fibaro?
    So far Logitechs home lineup only supports US frequencies. I do not believe Fibaro will support it imminently since ut is not for all regions.
    Hi
    It seems that the proprietary Harmony Hub protocol is "cracked" and documented:
    Please have a look at these link and consider if this information can support a Fibaro-"individual device command"- implementation?
    This is not actually true, The Harmony plugin does not use ON Off it uses change activity state, which is not so good. It means that if you create a scene or create a virtual device to turn off a Harmony activity and the activity is actually running you end up turning it on and not off.
    Dear Experts,
    Is there any update to control individual devices on the Harmony Hub via HC2?
    Working with activities is not helpful. I would like to just send individual commands to individual devices, e.g. TV Power ON or OFF. So that I can create a remote control using a virtual device @ my HC2. The above quoted code
     seams to do this. As I am not an expert I would be very grateful if somebody could help and share the necessary LUA code.
    Please let me know how to send individual commands on a Harmony Hub using HC2.
    Thank you,
    Alex
