Hi guys,
I need to ask you for help. I am doing one project and the client will have a equithernic heating system. So I have few question:
1- There is no equithermic Zwave thermostat available, right? So none of thermostats available now will use all the posibilities of equthermic regulation, am I right? Or do you know about any thermostat that could actually regulate the heating?
2 - So to use any Z-WAve thermostat (which are all ON/OFF) will work, but at the end it will be worst option as the original equithermic thermostat which comes with the boiler? That means recommending for example heatit or Secure SRT... will not be any better for a client, it will only add the possiblity to turn on and off the heating remotely, but it will be less comfy for them while they are home right?
3 - Now, if nr. 1 and 2 are true, is there any way we can connect this system with Fibaro?
4 - Do you think controlling the zones of underfloor heating will make any sense in this system? I mean, if fibaro will close all the zones, what will happen with the equithermic?
