Add activity to alarm
I have been trying to do something tonight, but with no luck so far.. Maybe someone can help.
I bought the Aeon labs gen 5 alarm, which nowadays works in HC (v4.056). It is recognized as a on/off switch.
What I'd like is to add an action to the alarm panel.. If the alarm is breached, then after 30sec the alarm should be turned on.
I can add additional actions, but that lets me select a scene..
I am perfectly fine with making a scene for this, but here is where I am lost.. As far as I know scenes work with IF-THEN statements, so I am kind of lost what I should use as the 'IF' part in such a scene..
Thank you all
4 answers to this question
If you want to make a block scene, you can choose a date/time in the past. So it will only trigger when the alarm scene will be activated. At least, I have done so.
Edit: Let me correct my post above: I've created a lua script for that.
In block scenes the condition is ignored, in Lua simply all the actions in code will be executed.
    Thanks, I will try tomorrow or the day after
    Indeed, let me correct my previous post. I have made a Lua script, not blockscene.
