vettori 0
I'm trying without success to make working an ZXT-120 (version 1.6H) with my air conditioner.
Going straight to the point, I found that HCL is reading the parameter 35 (Learn location status) in the wrong byte ordering.
I configured codes for OFF (location 0), ON (location 1), 19 degrees cool (location 2), 26 degrees cool (location 9). However on the advanced page of the device, the learnt reported location is 24 degrees heat (location 17) only.
The parameter number 35 contains the value 117571584 that in binary is 111 00000010 00000000 00000000. Looking at the manual this is means 24 degrees heat. However if you read the binary the other side (from right to left), i.e. 000 00000000 00000010 00000111 this means OFF, ON, 19 cool, 26 cool that are exactly the codes I configured!
At this point, I'm thinking that other values are being used reversed and that may be the cause why nothing works for me ?
I attached the manual.
Any help on this would be very appreciated. I'm using only fibaro devices on my HCL and they work great, the only exception are this ZXT-120 and an AEON Micro Smart Switch and both doesn't work as they should
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />Thanks
6 answers to this question
