Hi all
I would like to connect a Dimmer 2 in a electrical diagram as the one attached (It explains how to connect a Fibaro Relay Switch). I have tried different configurations but I have not managed yet how to set it up. Any help would be appreciated?
Regards
You have to connect the SX on your dimmer 2 to "Conmutador A". So disconnect from the live and use SX as input for your switch to bridge your switch over SX and S1. Rest of the connection pols are the same I think.
Hi all
Regards
The right manual (with diagrams) is here:
