I have a Dimmer 2 but I've some doubts about connection.
I read the manual but I don't sure if this wiring is correct. (see attach file)
My switches have 3 wires (l1, l2 & com) and I have a 2-way wiring system. (I need to confirm the type of commutation)
Thanks.
Looks fine to me. Just make sure these switches operate the way you think - that in one position there is live wire on L1/L2 and in other it is disconnected. And you can connect L1 also in the 2nd switch, unless you want it to work in other position.
    I have seen the type of commutation. (see attach file)
    It's a switch with a double commutator, the dimmer is only for one part.
    With this scheme I can't see how connect the dimmer 2.
    Another question, Can I connect the dimmer 2 with energy saving lightbulbs without dimmer options? I need the bypass?
