I have connected two Fibaro switches, each only has 1 device connected to them. (O1). Now, I want to set association so that when the the relay is turned on, the other one is also turned on.
I have tried Group 1 and Group 2, the homecenter seems to show the right associations. But they don't work, what am I missing here?
Can you give me exact IDs of every endpoint you have there (there should be 3 for every switch) and IDs to which you send associations?
    Yes... the first switch:
    183 >> 183.1, 183.2
    Second switch:
    187>> 187.1, 187.2
    Associations in switch number 1: 39 (this seems to be the right one in the UI), Group1.. also tried group 2.
    Associations in switch number 2: 38 (this seems to be the right one in the UI), Group1.. also tried group 2.
    You should set only 1st group in 1st switch, with 2nd switch. Note, that associations are only send when physical wall switch is activated, and devices must be in direct range, since association frames are not routed.
    Without a physical switch it is not going to work? Because there is no physical switch, so that will probably be the case....
    No - association only works if the switch is changed physically. Does not work if triggered through the HC / mobile appp etc. pp
    Ok, thank you for the clarification
    • 8 months later...
    So it is not possible that when i turn off Light1 from mobile or laptop, Light2 also turns off ??
    As it was mentioned before, associations work only via physical switch. They won't work via website or mobile app.
