I am trying to set it up but cannot get it to work.
At the lamp I have 2 wires, live and switched live. How to connect the wires into the module and lamp
/emoticons/default_icon_redface.gif" alt=":oops:" />  ?
I have connected like below:
Black-->L
Blue  -->N-->  Lamp
              ~ --> Lamp
It works fine in the app but when I use the swich it does switch off. But when I switched off via the app, no response via the toggle switch.
Also when I use the switch to switch it off the complete module gets inactivated in the app (probably because it powers down the module)
Also tried to switch Black and blue in at dimmer side but same behaviour. Also tried to use a momentary switch but that only works when I hold it down
Hope somebody can help me out on the wiring of this one ?
Guest fat
The problem is that you are feeding the module a switched live. This means that everytime you use your toggle switch you are stopping all power to the module. There are wiring diagrams available on the fibaro UK support page
Yes.
You need a third cable that is not switched or remove the switch or put the dimmer behind the switch where you are able to change the wiring.
Here are the links "fat" is talking about:
