Relay Switch S1 and S2 On/Off
Hi
I'm new to Fibaro and Zwave and have a couple of Dimmers, a 2 x relay and a HC2.
I have the relay connected to a porch light and a side of house light. I have two PIR's connected to S1 and S2.
I would like to be able to get a notification in HC so I can trigger a scene to turn on some other lights around the house. These other lights may already be on and so I can't do an association without going via the HC for the logic. I have done something similar with the dimmer module and switch inputs using Parameter 41 Scene Activation Functionality, but I can't find anything like this in the relay module.
Could anyone point me in the right direction?
Hi
The double relay module does not support Scene activation.
You will not be able to use the imputs separately. What oyu can to is to set the value of the lights as a trigger condition for the scene. That way the scene will run, and you an check if value is 1 or 0 to take apropriate action.
    Thanks JanJoh, that will work for my application.
