How to replace 20 switchers on the same place?
Hi guys,
I'm planning for the future flat the smart solution based on fibaro.
After calling the technical expert from the Conrad Stores in Germany  there still some questions according to the installation:
- do the dimmer/switch etc. componentns need the extra full power supply? (on the videos it was usually the normal switch, or all wall switches have power supply)
- if I have the conventional switch in fron of fibaro device, does the switch needs to be always on,  to allow the power supply for the fibaro dimmer/switch device?
And also some general questions:
- does it makes sense in the new flat to plan conventional switchers?
- are there any  despatcher boxes or any solution with the placeholders for fibaro devices available on the market to be able to plan everything on the one place ? (On the one wall/same Place I have 18 conventional switches: Light/Jalusie. Would be nice to replace them with Z-Wave Enabled or Touchpads)
- are there any solution to replace switches with texted Scenario List (Special z-wave power supplied controllers  or touch pad with app always on with scenario list  )
The Flat Plan is attached. Any help, idea will be very appreciated.
Thank you in a dvance.
P.S. In Germany  the KNX cabled Standard seems to be a non-alternative ( know-how/consulting leak). The price for the eight jalusie automation (eight buttons) offered for me from busch-jäger - 10 000 euro (sick!).
Are there any company making consulting in z-wave area? Seems to be a very promisable business. Actually in my future house could be more the 60 owners interested in professional consulting
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />.
