Merten Switch 5052xx Parameter
Which parameters must be set to turn the 2-way pushbutton to a 4-way pushbutton ?
There are the parameters 0 and 4 parameter, only the values that need to be set umd the button to use so that you can put an Association for keys 1-4 and with each button can control a device?
I get it only now that the left side (top = on and buttom = off) the same applies for the right side.
According to parameters I think it would be but it is possible to implement the following function:
Top left (first push = on / second push = off ) 1. Function
Bottom left (first push = on / second push = off ) 2. Function
Top right (first push = on / second push = off ) 3. Function
Bottom right (first push = on / second push = off ) 4. Function
Would be glad if someone could help me.
4 answers to this question
I hope this manual vil help you out:
Hi! I also have the Merten wall switch, but I really do not understand how to set up this device. I have the parameter list, but each parameter value can be set between 0 and 127. I really do not know what I'm setting by changing these values. If you understand this configuration can you please tell me how?
Reve,
First i seams the template in fibaro HC2 is wrong, se the linked document from hkmod25, It also makes sense if you read the documents I have linked at the bottom of the post. So you need to uncheck "use templates for parameters" and define the parameters 1, 2, 3 and 4 your self.
If you want to associate 4 devices instead of 2 i THINK you need to set parameters, I have not tried the single control surface configuration myself:
0: 4
1: 4
2: 4
3: 4
This should give you the possibility to add association groups 1, 2, 3 and 4 = two groups for each rocker one for the upper part and one for the lover part.
If you configure all 4 parameters to 0 you will have only association groups 1 and 3 = one group for each rocker (I think this is default if you reset the device.
Oficial metren documentation can br found here:
Also see this post
  by @nukeman
Thanks, now I get it!!! The Fibaro template is completely wrong, not even close!
