[SOLVED] Fibaro roller shutter 2, problem with Venetian blinds, help!
So I have 7 FGRM222 EU in my house, I only used to have 4 but now I bought the 3 that was missing. Yesterday I installed them and one of them refuses to work properly. The Up/Down work nice, but when I try to put my lammels at 50% for example it won't work.
My Parameters:
Device uses global polling;
Venetian blind;
3 - Blind position reports sent to the main controller using fibar command class;
12 - 2.4s;
13 - lamellas return to previously set position only in case of the main controller operation;
14 - toggle switches ( even I don't have switches connected to my rooms venetians );
The rest is default, the strange thing is that the other are all worming but this one is getting me frustrated because it doesn't want to work. Already changed the Fibaro Module by another, excluded it from HC2, reset module eprom, restarted HC2, but all with no luck.
I'm using HC2 4.056 SW version, with 18 devices, and polling time interval of 125 ( recommended).
Hope someone can help me. :/
Thanks.
    So I got it, I don't know if this is a bug or not, but in the others I db't have to do this step. when we go to 'Device'/Settings there are two modules, one master and one slave. I always configure the slave one, and it used to work. in this one, I've got to go to the master ( that is hidden in the system ) and change Parameter 10 from Default to 'Roller blind and venetian blind positioning active'.
    Thanks.
