Mo19 1
Hi all,
We have installed a few Dimmer 2 in a house and just now we received info from the customer that something is wrong with one of them.
The transformers are dimmable Osram electronic transformers 105w on which you can see that it supports leading and trailing edge dimmers...
The bulbs are Toshiba 5w dimmable LED bulbs.
At first, everything is OK because they work super, no buzzing, no flashing no noise nothing!
Now, the biggest, so to speak, ciruit with 8 bulbs started o flash like in a disco. At least that is what the customer said... When you dim them to 100% it works OK, but when you start to dimm them they start flashing.... Any idea what may be the problem? The other circuits are 5 and 6 bulbs.... The dimmers are connected to 3 wire electrical system (with N)....
Please help... Not sure where is the problem and from where to start?
28 answers to this question
