netatmo rain gauge scene for sprinklers panel
Hi
I created a simple scene - if netatmo rain gauge reading (from netatmo pligin) is > 0 then press the button on my VD. This button then adds a rain delay in sprinklers panel. It seems to work but after some time, I can see the sprinkler rain delay in the panel to be 49 days.... Can you have a look what could be wrong? Could someone help me modify the scene to check the rain gauge value every 55 minutes rather than on every value change? (as i think this is the problem)
Scene:
Button in VD:
7 answers to this question
    guys could anyone help me? I need to press this button every hour when rain gauge is > 0. seems simple but does not work.
    U mnie podobne, oparte na tym samym kodzie rozwiązanie działa bez zarzutu. Mam VD i tam przyciski z opóźnieniem podlewania (8,12,24 godziny itp) odwołującym się do panelu zraszaczy. Prosta scena w bloczkach, że jeśli deszczomierz >0 to naciśnij przycisk plus timer resetujący co 12 godzin (to zależy już od konkretnego ogrodu, czy sekcji - u mnie 12 godzin)
    a u mnie zonk. Netatmo jest np 1.8 opad, wchodze pierwszy raz do sprinklers panel i ok opoznilo mi o 1h (tyle chce) , ale wejde za chwile i juz widze 49 dni!
    Fibaro - I am 99% sure  it is not an issue with my VD but with sprinklers panel!!!
    I tried to manually press the VD button 20 or more times and it works correctly - delays sprinklers by 1hour. But then when I go to sprinklers panel i suddenly see 49days delay (or more!)
    Can someone from Fibaro comment?
    I have set manually 1h delay. Closed my laptop for a while and reopened. Here is what i have:
    and api/panels/drenchers
    I clearly did not set such rainDelay !!!
    anyone knows what is going on?
    Steps to reproduce:
    1. Set sprinkler delay to 1h - either using Virtual Device or manually in the sprinklers panel
    2. Wait for some time, navigate away from sprinkler panel
    3. Go back to the panel after 15-20 minutes
    4. Sprinkler delay will show CRAZY values (in days)
    Have a look at the screenshot
