Qubino Relay Switch Flush 1
I am looking for a relay switch with a possibility to measures the instantaneous energy used (in Watts) and the total consumption (kWh). Could somebody could please confirms that this switch works with HC2 4.056 and it is fully compatible.
7 answers to this question
I was wondering the same! My research concluded....
Looking at the
  they say nice things and the
suggests we'll be fine if using HC v4.x or everything but the temperature works under v3.x
Guest samuelboerhoop
All those relay modules from fibaro or qubino are using a fixed power consumption reading > under the advanced tab you have to type in the amount of power it is using. Fixed amount!! So if you connect a TV to this module then your reading which you declared was 100W, will stay as a 100W TV, it doesn't change.
When you use the Wallplug from Fibaro it does change, the only thing is that you can not change the icon at the moment
Hope that helps to understand
    Thanks for that. All clear. What about Aeon realy switch? Is it working like wall plug?
    no experience with
    Qubino Flush On/Off Termostat supposed to provide such a feature (consumption monitoring). But I dont know if its compatible with fiabaro HC...
    Not compatible with 4.057 or older.
    Thanx, I already sent a message to you to get this info
    This device is looking promising, its a shame that Fibaro is not able to include it faster into its environment...
