Chrisvr2 0
I created the following scene:
DeviceID 17 is the power used, DeviceID 47 is the amount of lux measured.
I use this script to switch on the lights if I turn the TV on. Depending on the sunrise and sunset, or the amount of lux in the living room.
If I turn the TV of, the lights turn off after 5 minutes.
2 Questions:
- Can I make this script smaller/better?
- I would like the lights to remain on when I turn the lights on manually (though fibaro). Currently, the lights will not stay on if the TV is off, and I turn the lights on manually.
Thanks for the help!
