Main loop are still stopping working...
Hi all
I have again scenes with main loop that stop randomly. It was something I had with older 3.x versions, except 3.597 and 3.6 where it appeared to be fixed...
But since I migrated to 4.056, I have again this behaviour !!! I just have to save the scene and it restart working properly
Does someone noticed this ?
7 answers to this question
Hi Quikdav, please give more detail, example code with what you got problem for reproduce, because i can say that mainloop is working and we both gonna have right, and because we can't reproduce it you gonna wait forever for fix that
    Thanks for your reply...
    Here is the code from the main loop. It is just a device that display the content of a global variable. It was freezed again so I saved the script and it restarted. Same with an other device displaying same type of data. As mentionned, It disappeared in 3.597 and 3.6 and it is the third time I restarted it since my migration to 4.056 (about 1 month)
    David
    A.Socha I had similar issue. I had main loop in VD which checks one device state, and changes the Icon (representation of garage door). It stops working on 4.056, after I restore backup. I deleted it, create again, and again. Still it happens.
    I also have the same issue.
    After 24h the main loop stops. If I go to the VD / Advanced and push the save button the mainloop starts again working.
    My HC firmware is 4.056.
    Is it possible, to restart/reset a VD with LUA-Code ?
    I don't have that problem, possibly because I don't use Net;FHttp in a loop. I don't think there is a way to restart a VD.
    I remember reading this topic, and I think there is some good advice in it:
    It's mainly about using "pcall" and workaround I could summarize as "pushing VD buttons from a scene".
    Hi Peter!
    Thank you for sharing this topic - that sounds really good. (Put it on my list too
    /emoticons/default_icon_wink.gif" alt=";-)" /> )
    First I did the main loop without any delay, it hangs after some hours:
    then I did it with 1 minute delay and it worked for one day, now I have a 5 minutes delay and it is still working.
    If it hangs on the 5th day I think there is some kind of 'overflow' in the HC2 ...
    Please use this code in your looping program:
    With this code my program never stops
