I have a FGD212 Dimmer 3.2 that I use to switch both relays on my two FGS222 Switch 2x1,5kW.
One Click for relay one, double click for relay two.
The lua code of the scene looks like this:
Now I wonder if there is a possibility to do something like this with association. Because I have this 10 times or more. And it would speed things up and it would then even work when HC2 is down.
Is there anywhere a good guide for multichannel association and things like that.
Thanks for your help.
I think it is not possible to use associations like this with FGD212.
Both actions (one-click) or double click are sent to the same association group. You can only use associations from button S2 (association group 4 & 5) and change configuration in parameter 24/25.
    Thanks for your help. I changed my code for some dimming and all works fine. Now I would like to do the single click with a association to make it as responsive as possible and do the rest with the lua scene.
    The lua scene doesn't work any more, since i have the association. What did I wrong?
    I found my problem
    I used clear association and deletet Group 1.
    But again is there any good guide for association. I don't realy understand how it works.
