Realtime events/triggers with REST API
Hi to all, i'm studying Fibaro REST API
but i find only information about calls and fetch info. Seem only one-directional interface.
For example, the Motion Detection sensor. How i can obtain in realtime the event trigger?
I need to fetch every seconds the device info to detect it?
In some other REST API of other kind of service, for example, it's possible to subscribe an event by providing a callback URL, and system will call it when an event occur.
I'm missing something? Thanks for any advice.
Clodo
9 answers to this question
    , at least, have an API that list every changes in zwave network occured from a timestamp param.
    Exists something like that in Fibaro, or i need to fetch a lots of data and device every seconds?
    I use a scene on the HC2 and it calls the api of the Raspberry (for example scene triggered by "motion"). I'm pretty sure this is the only workaround. I've never seen or heard anything regarding "callback" on HC2.
    As far as I can see there is way to poll the HC2 events, which is used by the build-in Event panel.
    Get last event update number:
    Returns some thing like:
    The event update number will keep increasing. Note that on event update can contain multiple events etc, which can be collected like this:
    It will return json arrays for logs, events and changes.
    This way you can iterate back in HC2 history
    @snitkjaer wellcome to the forum! I see you have resurected a topic from 2015 but that is OK ;-)
    Yes, indeed, you can "poll" the event log. I have no idea how "expensive" that is. I use it to collect data for off-line analysis only.
    @petergebruers Thanks :-) I know it's an old topic but I came in from Google thus I thought others might as well.
    I doubt it would be to expensive if we just poll say every 300 - 1000 ms, which should be "real time" enough for most uses.
    Anyway seems there is also a way to get just old events in case that is needed:
    I'm writing a small program to periodically collect and store the events in a DB for analysis
    In that case, I suggest you use IDs to synchronize your data (url like "?from=<ID>"). Because timestamps are not unique and have limited resolution (seconds). So to avoid duplicates and ordering problems, I would always use the event ID. It is guaranteed to increment.
    You might be interested in these two topics:
    Does this help? In that case, you can show your appreciation by "liking" this post... If it not, please tell me how I can improve my answer...
    Edited by petergebruers
    fixed filter by ID
    Have fun with Home Automation!
