Problem with scene running only at night with motion
I have Scene but don´t get it working right. If there is a motion from 1:00 and 2:00 at night light should go on.
Now it always turn on when there is motion
You need to add (at the end) a line for the light off "TurnOff" at a certain time (red Box).
  • 1 month later...
how to do this? i can only add (and)
Guest fat
I use a global variable to do this. I have created global a for morning, afternoon, evening, and night times. You can then create scenes that will run only if it is a particular time of day
how you made this..?
i tryed it but light not going on
Guest fat
Do you have HC2 or HCL?
See screenshots, this should work.
@Fat, HC2 and thanks for the help
@Boerremk, moet je deze niet op 0 ipv 1 zetten dan? en moet deze aan
? Ik vind dit een mooi aparaat alleen een uitleg over wat wat presies doet mis ik echt bij Fibaro.
The block scene I posted will work (it tested it before I posted it
/emoticons/default_icon_wink.gif" alt=";-)" />). I can also make a lua script if you want that will do the same.
If you want more information in Dutch please send a PM
The scene is working thnx
