Problem with time, please help
Hi guys, I'm having problems with my scenes, and I think I know why,
If I made I simple Lua script with:
I get this as response:
What is going on with my HC2?
Help me please!!!
Thanks.
4 answers to this question
    Ok, I got a PC so I can remotly do some tests. My Pc was is same timezone as HC2, for harder that I tried the hour won't change, the trick was changing it to manual set time, save and them change it to automatic time from server again.
    Thanks once more Peter
    I'm not sure... but I'm curious!
    I added Daylight Saving Time flag and UTC time to the script. What does it say? Does it make sense for your locale (Portugal = WEST timezone, currently UTC +1)?
    @petergebruers here is the debug:
    Are your PC and your HC2 set to different timezones? In that case, can you please match them up and try again? Or set both to timezone Europe/Brussels. Then you should have 2h difference between UTC and local time. Then try to set both (back) to Europe/Lisbon...
