philips hue startup color
hi,
can anyone share if the philips hue bulb can be configured in fibaro HC 2 to startup with a specific color and dim level?
thanks
6 answers to this question
Create a scene and fill in like this:
I already search all the time for simple solution. Thanks a lot.
    thanks Frakke, I guess this will this have the effect where you can see the light changing color very quickly when it's switched on?
    that should still be fine though
    thats not a problem you can change the order
    make it like this
    Is it correct that it is not possible with the block scenes function?
    Where can i find this information on the web for setting these values?
    Especially the settings for the color.
    Robert
    Frakke,
    Where can i find the information to use for using commands for the Hue lights as you mentioned?
    Is there somewere documentation where i can look for all commands?
    Robert
