In my Fibaro lite centre I have some devices that seem not connected to the network any more, my hcl is second hand and I don't have those devices. I try to delete them and it says something like "NOP succeeded, device wasn't remove, use learning mode"
How can I delete those devices? IF I don't have the device itself I can't use learning mode to delete it!
Here's a picture. Deleting the whole dimmer from the network removed all the hidden devices too.. So I add it back and it appeared as 9.1, and it brought with it 3 other devices called 9, 9.0 and 9.2. I renamed the active one as Lounge ceiling to help remember which it was
Note also that this dimmer is second hand too, it may have been associated with other devices in its past life. Is at why it brings hidden devices with it? How do I reset it?
Why did it do this?
