Email notifikation do not work. See attached. whats wrong??
So I want to test notifikations.
I make a variable and want a notifikation when I set the variable to "1".
I go to the variable panel, set the variable to "1" and nothing happens?? No email to me
Can it not be done this way?
Can it be done another way?
Make sure that Active scene is checked.
I believe you also have to check "Start when HC2 starts", otherwise the check of the variable will only be done when the scene is run manually or from another scene.
You can not go to variable panel and change var. You must change it thrue a scen or vd to make it work.
    Ok, thanks.
    The scene is OK, but can not be activated by modify the variable from the variable panel. The variable has to be modified from another scene ect. via a timer, then it works.
    Thanks for your response.
