because of my problems with one of my Door-Sensors I buyed two new one.
But I can't include them !
Tried it in a distance of 50cm from the HC2.
Opened, removed the Paper from the battery, closed it and then pressed the back button 3 times.
Also tried to press the inner button 3 or 6 times while the button on the back is pressed.
No chance !
Is there anybody who knows why ?
Best regards,
Axel
does the led starts blinking when you push the button?
The easiest way is to close the cover and then click bottom button 3times, if it doesnt work, push again 3 times.
If this doesnt work then try to delete the sensor from HC2 - this will reset the sensor also.
Lauri
