So I have connected the Schneider Ulti switches with the Fibaro 2 X 1.5 relay. What is happening is that the relay keep turning ON and then OFF. This cycle keeps going on.
What I have observed is that the Schneider Ulti has an indicator LED that turns on only when the switch is turned off. Resulting in a leakage current from the switch to the Fibaro Relay on the S1 terminal. The Fibaro relay interprets the leakage current as a signal pulse from the switch and turns it on, after 3-5 seconds it turns off then again after 3-5 seconds this turns on. This cycle is endless.
How do I restrict the leakage current to S1?
Cheers!
