Hey all,
I'm using a couple of Fibaro FGMS-001 Motion Sensors to control lighting in my hallway. I'm using them with OpenHAB and have a rule that acknowledges motion, turns the light on, then after 5 minutes turns the light off. This works well, regardless of whether the motion sensor turns the light on, or the manual switch.
The problem I have, is that, when the light goes off after 5 minutes, I am unable to immediately trigger motion again. I suspect this is due to the parameters I currently have set, and my lack of understanding about what they do.
Ideally, I want to 'disable' the PIR/motion sensing for the duration of the illumination, however, there doesn't seem to be any kind of parameter that will allow me to do this.
I've played with options 2 and options 6. Option 2 sounds most like what I want, but I can't define that as any higher than 15... Option 6, I have recently changed from 120, to 20, and this doesn't seem to have made any difference whatsoever.
Any ideas?
OpenHAB rules if anyones bothered;
Hey all,
Any ideas?
Have you tried the parameter 2: down to 1 or 2
    I haven't, but I shall
    Dropping option 2 to "3" and updating my rules to;
    rule "Turn Downstairs Hallway Light off after 5"
    when
        Item Toggle_2 received command
    then
        if(receivedCommand==ON) {
            if(tDownstairsLights==null) {
                // first ON command, so create a timer to turn the light off again
                tDownstairsLights = createTimer(now.plusSeconds(300)) [|
                    sendCommand(Toggle_2, OFF)
            } else {
                // subsequent ON command, so reschedule the existing timer
                tDownstairsLights.reschedule(now.plusSeconds(1))
        } else if(receivedCommand==OFF) {
            // remove any previously scheduled timer
            if(tDownstairsLights!=null) {
                tDownstairsLights.cancel
                tDownstairsLights
    = null
    Seems to have helped
