Disable timer on thermostat
Hi!
Does anyone know if there is a way to make the SRT-321 thermostat keep the temperature I set on it until it gets a new temp from the heating panel? To me it looks like you have to set a certain amount of time for the set temperature to last.
Example: I have a room where the heating panel sets the temperature to 16 degrees every day at 23:00, because I only use it maybe once a week in the evening. So when I know I'm going to use it I just turn the wheel to 22 degrees. But it looks like I have to set a certain amount of time for that to last in the web interface. I just want it to last until the heating panel tells it to go back to 16 at 23:00.
Does this only apply when you use the web interface and not when you turn the set temp wheel on the device itself?
