Hi guys!
Since a long time I've been looking for a new and nice watering system to manage my garden sprinklers...and finally i've found this...
this look really smart, works with wifi and ethernet, works with koubachi wifi sensors, netatmo, and parrot flower power and calibrate water quantity based on sensors and wheater forecasts!!! great!!!
Do you think is could be integrated in fibaro UI??
I'm not using it myself, but isn't a lot of this functionality handled by the sprinkler panel? You only get the hub, which is quite expensive, and since you already have a Fibaro, you already have a hub?
Personally, I think the hard part is the sprinkler system itself, so the valves and the the way to connect and control them. If you have a suggestion for an easy package for the actual sprinklers, I'm game!
    yes this thing is quite expensive...and the sprinkler panel could make 50% of work...but the panel is not managing water distribution using data from sensors and from weather forecast right?
    I think it can only stop water if weather says it is raining...
