The motion sensor doesnt show correct temp.
IT seems to report with 4-6 hours delar.
Any ideas?
not sure what you have done so far. But this might help. Go to the Settings of the sensor and check Parameter 60. This defines at what Level or Delta the sensor sends the Change to the HC. I have set it to 0,5 degrees. So once the temperature changes by 0,5 degrees the sensor will send ist Change to the HC. Parameter 62 & 64  set to 900 sec.
To make sure that the Settings became active I wakened up the sensor by klicking it three times...
Does that help?
kandetvara
    Thanks for the tip,
    But it seems that there´s yet another bug when setting the slider to 0,4 and saves it sets:
    [18:24:30] ID 24: Set parameter 60, value = 7
    Setting Default (1) it sets:
    [18:24:30] ID 24: Set parameter 60, value = 10
    Is there a way to edit a text file for this? Using HCL
    No Sure what you mean...
    edit a text file? for waht reason?
    Thinking IF the slider gui has a bug. Not possible to set to 0,5 degrees.
    I guess there's a XML or textfile in the background.
    Thanx for the tip about 62 and 64. Think it updates more frequently now.
    It still showing 2 degrees wrong though.
    • 3 weeks later...
    There is a bug, the slidebar accept float numbers but the variable is integer.
    You can try to se the range to 25.5. but the last set variable going to 255 (integer)
