Hey,
i want to use the FGD221 to switch a lamp.
The Lamp ist not dimmable in the moment, but perhaps i want to use the funktion in future.
So is it possible to use the FGD221 without the dimming funktion or is there a perameter to disable it?
There is no FGD221. Only FGD-211 and FGD-212. Do you have the manual? It can be downloaded from the Fibaro main site. For Dimmer 1, look under parameter 13. I'll sum it up for you: param 12 = 99, param 13 = 98, param 10 = 0. Dimmer 2 uses a calibration mechanism and it will detect a non-dimmable load in 99% of all cases. For those 1% that it doesn't, similar (but different) parameters exist.
    Thanks for the answer.
    Typing error. Its FGD 211.
    The setting of the parameters is logical for me.
    But what do you mean by Dimmer 1 and Dimmer 2?
    FGD-211 = Dimmer 1 = old dimmer
    FGD-212 = Dimmer 2 = new dimmer (redesigned for all kinds of load, especially LED)
    OK, but the operation manual of FGD-211 says:
    As the Dimmer it operates under the following loads:
    -conventional incadenscent
    -halogen 230V
    -low voltage halogen 12V-
    -dimmable LED
    Yes. What is your exact question? I don't understand what you are trying to say...
    Oh, it's a riddle! I get it! It's because I said : "Dimmer 2 (...) especially LED".
    The FGD-211 is a leading edge dimmer.
    The FGD-212 can do leading and trailing edge dimming. That's one of the new things. There is more... Z-Wave Plus, better protection, different connector, etc. But dimmer 1 can do LED that are dimmable with leading edge... Dimmer 2 "auto configure" will test the load and select the correct settings for you. No need to worry about "leading" or "trailing".
    Thank you,
    you helped me a lot.
